Version: Windchill 12.1
Use Case: When checking in data starting from teh WGM Add-in in solidworks.
Description:
When I want to check in my data from Solidworks, I can right click on the part in the WGM add-in and select 'auto Check In',
But the 'Undo check out' is just above it. When I click this accidently, all my data is lost. Can this be changed so they are further apart? (for example 'Undo Check Out', 'Check Out', 'Auto Check In', 'Update',...)
Or a least get an extra window with 'are you sure?'.
Hi @IS_10877309,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
