Mayur, thanks for the tip, you're right (I actually hasn't noticed this until now). But there is a new file in 9.1 -
psi_iir_index.xml and it's stored in
"c:\Documents and Settings\Administrator\Application Data\PTC\Windchill\" so seems you still have to login as the same user, who installed Windchill (or manually copy the index to the Doc&Sett of the user who is trying to update).
Christine, do you have the
"c:\Documents and Settings\<user_name>\Application Data\PTC\Windchill\psi_iir_index.xml" in your Documents and settings? If no, copy it there from the Doc & Sett of the user who installed Windchill. If you have the file, have a look where it points and check the
psi_iir.xml in that folder. There should be something like:
9ddbac0b7d
Make sure you have
isInstalled="true" next to the modules you have installed.
