Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I've downloaded the files for the M070 WGM client, but there's no .exe or any way to install it. I just want to install this version of the WGM on my desktop to test compatibility of Solidworks 2009 with Windchill in preparations to begin migrating to the new software.
