User And Cabinet Structure
KS_9212978
6-Contributor
UserAndCabinetStructure
Diagnostic task reports the AdministrativeDomain of users, the corresponding LDAP node for each user and also the AdministrativeDomain of the user's Personal Cabinet. The output of this task is a text file.
Tue 6/27/23 12:41:26: Total number of users in the System: 15065
Tue 6/27/23 15:33:28: Error in method server code:
Tue 6/27/23 15:33:28: java.lang.Exception: Exception of type 'java.lang.reflect.InvocationTargetException' was generated on the server with message 'null'
Tue 6/27/23 15:33:28: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Tue 6/27/23 15:33:28: at java.lang.Thread.run(Thread.java:745)
Tue 6/27/23 15:33:28: Task failed.
Tue 6/27/23 15:33:28: com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate User and Personal Cabinet Report (#UserAndCabinetStructure)
Tue 6/27/23 15:33:28: Nested exception is: (com.ptc.windchill.upgrade.updates.directives.directivesResource/39) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Method server code wt.org.UserAndCabinetStructureDT.executeDiagnosticTask failed. See nested exception for details
Tue 6/27/23 15:33:28: Nested exception is: wt.util.WTException: java.lang.reflect.InvocationTargetException
Hi KS_9212978,
Thank you for your question.
Please provide details like the issue you are facing is for any Specific release of Windchill?
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team
