Using SequenceGenerator in code
VasiliyRepecki
Hi, all.
I need to use SequenceGenerator for WTPart in java code.
I have tried setNumber(SequenceGenerator.generateValue("WTPARTID_seq")) but result was not i expected to see.
Now i am trying setNumber(SequenceGenerator.generateValue("{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}")) but it throws SQLServerException: Index 1 out of range.
Can anyone give me working sample?
Thanks.
KD
(To:VasiliyRepecki)
Try this PersistenceHelper.manager.getNextSequence("WTPARTID_seq");
or this
EnterpriseHelper.getNumber(new Object[]{"{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}"});
Kaushik
sravi
(To:KD)
Hi Kaushik,
Since the getNextSequence(String str) method is deprecated, is it safe to use this API method?
Srini
KD
(To:sravi)
Hi Srinivas,
Yes the API you mentioned it's deprecated.
But the other one which I mentioned
is not deprecated so you can use that.
The OOTB code internally using getNextSequence so it may b safe.
Kaushik
sravi
(To:KD)
Thanks Kaushik!
