Hi, I couldn't find any information in the documentation about this.
Is it possible to enable the "View ERP part details" function in the UI without using the Tibco integration tools for Oracle or SAP? We're using a custom integration tool to our ERP system (Microsoft Dynamics) and it would be really useful to have costing and stock information available in Windchill for the engineers. Has anyone managed to get this working for any other system than SAP or Oracle?
Thanks in advance!
I know only the ESI (Enterprise system Integration) as a connector to SAP or Oracle. from PTC. Others connectors are from a third party and it is not just configuration. You can search a Windchill Extension applications that are available OOTB in Windchill 12+ but nothing is just configure one property and all will work.
PetrH
If you have a connection to the databases of the ERP system you can drill out the information based on the ID from Windchill if it can fit. You need the same identification parameter in both systems.
You can get the information and show it by data utility in the Wndchill.
It is up to you how you get the information. if you use own custom solution then you would use already exists functions from it
If the ERP has a rest api you can use it by java code,
If the erp use HTTP server you can use HTTPURL call from java and so on.
PetrH
Thank you Petr, so it's only customisation then? I was rather hoping that it would be a preference or an xconf somewhere to tell Windchill how to access the data using some pre-defined connector.
Chris
For clarity. It's this function that I'm trying to enable: Viewing ERP Part Details (ptc.com)
PetrH
Thank you Petr,
I thought that this might be the case. Thank you for your help.
Chris
These are some HUB articles about ESI, Tibco and ERP systems.
[Knowledge Hub] Windchill PLM - Enterprise System Integration
[Knowledge Hub] Windchill PLM - Enterprise Application Integration TIBCO
[Knowledge Hub] Windchill PLM Enterprise System Integration - Customization
I think it is by far the most complex part involving Windchill.
We use Tibco to integrate Windchill with our ERP system, and the configuration of Tibco is totally in the hands of our consultants.
