I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS23
How to see in WT-Part Structure Visualization which Reference Designator is assigned to which Occurence in 3D?
When selecting a Part in visualization, I can't find any information which Reference Designator is assigned to it. Also when selecting any Occurence in the Occurence list, no object is being selected in the Visualization tab.
Hi @CHENAMA
Try to use Show occurances and then try to use select visualization. It should help you.
PetrH
Hi @CHENAMA
PetrH
