some of Solidworks 2D drawing is not converted into Viewable, It happens rarely.
leehansung
3-Newcomer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS20
Visualization Worker do not make 100% viewable file from Solidword 2D Drawing.
I found A part of Solidword 2D Drawing is missing when I see the viewable file with Creo View, But 2D Drawing have the part that Creo View Adapter did not transfer to viewable.
Here are the errors that I faced
No Error Message , Queue Manager say it have success to converse the Solidworks 2D to Creo View Viewable.
I have seen this when I was importing drawings during a migration.  The parts were loaded in and then I loaded the drawings. In some cases, it was showing the drawings being blank in that it was not pulling the references. Are these drawings you are normally working with or is this a migration?  I believe that Solidworks looks for references in the last place it pulled them from? Is it that the references were not updated? Can someone confirm that?
