WTPart visualization disappears after check-out and doesn't regenerate after check-in
ZANET
8-Gravel
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.3
We are experiencing an issue with WTPart visualizations in our Windchill environment. The problem occurs in the following sequence:
-When a user checks out a WTPart, the visualization immediately disappears (which may be normal behavior)
-The user then makes changes to classification or other attributes (not CAD geometry)
-After checking the WTPart back in, the visualization is not regenerated
Could you please advise on the correct configuration needed to ensure WTPart visualizations are properly regenerated after check-in when only attribute changes are made?
Thank you
HelesicPetr
(To:ZANET)
Hi @ZANET
It is general behavior if the copy forward representation is disabled.
Here is an article that describes how to enable copy forward representation just for the WTPart
CS61223 - Viewables are not copied forward upon iteration in Windchill PDMLink
Set following wvs.properties by xconfmanager
publish.copyrepresentationsforward.restrict=true
publish.copyrepresentationsforward.part.restrict=false
Also check a Help Windchill Help - Copy Forward Properties
PetrH
rhart
(To:ZANET)
What kind of associations is it, between the CAD and WTPart, Owner, Image, Content, Calculated?
HelesicPetr
(To:ZANET)
Hi @ZANET
PetrH
Thank you @HelesicPetr,
my conf publish.copyrepresentationsforward.restrict was false.
I've set these two others, and it works fine.
