Hi Antonio,
we have the same need for a project we are doing.
We are implementing MPMLink to manage objects in a multi divison system in SAP, trough Tibco integration.
Our SAP key users wants Windchill doing things like SAP, like you explained: do a search by number and the execute mass change of attibutes or lifecycle.
Our consultants said they could do a customization to do that, but it could be better if similar way of using SAP will be available also in WC, for example copy the list in SAP and paste number in Windchill then execute mass change.
At the moment we decide to implement customization, but because change can be send to SAP only with manual republish or with mass change of LC (and our key users don't want to use this way) this customization it will be use only when we will activate ECN. Until that moment we will execute mass chenge in SAP and send modified data to WC trough an export in text file and then aligning WC in semi automatic mode.
I forgot to say that if you create an idea on PTC community, you will have my vote
Related to this would be bringing back the "Briefcase" functionality that was in the old 3.x Pro/Intralink days. The briefcase would allow you to collect a variety of objects via search, browsing, etc., and then perform actions on those objects.
You can search for multiple objects now by separating the keywords with a ";". It's handy for small lists. I don't know if there is a character limit to the keyword though. I image there is one.
One continued annoyance with the search results list is the limited actions that can be performed on the objects in the list (like set state on multiple objects at once from the results list).
Daniel Nordin
BAE Systems
Pro/Intralink 10.1 M030
We programed a very simple modification to Windchill and achieved similar functionality using the search, select all, copy and paste functionality.
Hi All,
You can try the following way to search more than one Number/Name
MKR
Hi Joginder,
can you please give some more info on what you do, to achieve what Antonio ask?
Hi Joginder,
In Reply to Joginder Matharu:
