What type should be the variable obj ?
VladiSlav
Hello, please tell me what type should be the variable obj ? I found an example of editing a template https://www.ptc.com/en/support/article?n=CS150777 , but there was a problem with the type of variable, tried everything I knew and everything that was recommended, it did not work to pass the test.
CODE:
​wt.maturity.PromotionNotice notice = (wt.maturity.PromotionNotice)primaryBusinessObject;
                 wt.fc.QueryResult results = wt.maturity.MaturityHelper.service.getPromotionTargets(notice);
                 while (results.hasMoreElements())
                          obj = results.nextElement();
                          if (obj instanceof wt.doc.WTDocument)
         var += obj.getName ()+“,”;         // var  is a global variable
TESTING:
Checking Syntax...
warning: Supported source version 'RELEASE_7' from annotation processor 'com.microsoft.azure.management.apigeneration.LangDefinitionProcessor' less than -source '1.8'
WfExpression_11.java:57: error: incompatible types: Object cannot be converted to Persistable
Note: WfExpression_11.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 error
1 warning
Syntax check complete.
8 REPLIES 8
Didn't the reply by @zsternal-2 in this thread help?
Ok sorry, just saw your reply there. I think there is something wrong with your code. Is this what you wrote after the suggestion from @zsternal-2
wt.fc.Persistable persistable = (wt.fc.Persistable) resulting.nextElement();
If yes, and it did not work, please post the full code.
yadavankur, unfortunately the answer did not help, the error is the same, already many types tried
yadavankur, this is the whole code, nothing else was added
wt.maturity.PromotionNotice note = (wt.maturity.PromotionNotice) primaryBusinessObject;
wt.fc.Query Result results = wt.maturity.Maturity Helper.service.getPromotionTargets (note);
    while (results.hasMoreElements ())
        obj = results.nextElement ();
            var + = obj.getName ()+ ","; / / var-global variable
So this is what you are missing
        obj = results.nextElement (); //replace this with below
        wt.fc.Persistable obj = (wt.fc.Persistable) results.nextElement();
I find your stack trace intriguing though. Is your Windchill instance on the cloud? I am still confused by the presence of this line "com.microsoft.azure.management.apigeneration.LangDefinitionProcessor"
yadavankur, thank you very much, the test passed, but there was one more question, I put a String type for the variable MyValue, but only a comment appeared on the page, then I assigned the value "Test number 6" to the variable var at the end of the code, it appeared, it turns out that the variable var remains empty if you run the code?test.JPG
Has the local variable been initialized from and copied into the global variable? These were options when you were creating the local variable.
yadavankur, yes, initialized the variable, maybe the code itself I misunderstood what it does and how to fix it to get the table and display it
