Ron,
Since I have a near identical setup, I decided to play around with things a bit and found that you can reconnect to your workspaces if you put in 'ilcs://' (without the single quotes) as your server location under the Register New Server option in the Server Manager window of WF4. I am assuming that this is what you wanted to do.
Running WF4 m190 and Ilink3.4 m062 on a Lenovo W700 with Win7 64-bit.
