While checking in one assembly I am getting error mesaage as Error message - New object "Assembly - 1901065.asm" has the same filename that already exists in the database in a restricted context. In order to upload this object, you must update this o
RanajitPawal
Error message -
New object "Assembly - 1901065.asm" has the same filename that already exists in the database in a restricted context. In order to upload this object, you must update this object in the workspace
I sse that 1901065.asm is not present in the commonspace. I am not sure whather it is present in other product.
Can anybody help me in resolving this problem?
Thanks and Regards,
Ranajit
BenLoosli
(To:RanajitPawal)
If you have admin rights, it will show up in a Windchill search.
If you don't have admin rights, it may be in a workspace that you don't have visibilty rights to.
Find out who has already used that number and ask them to rename it or rename yours and check-in.
Search "1901065.asm" in windchill if existed, rename or delete the file and upload/checkin the new one.
Thanks for your inputs. I had to rename the assembly and check in the same.
-Ranajit-
BenLoosli
(To:RanajitPawal)
