Error message -
New object "Assembly - 1901065.asm" has the same filename that already exists in the database in a restricted context. In order to upload this object, you must update this object in the workspace
I sse that 1901065.asm is not present in the commonspace. I am not sure whather it is present in other product.
Can anybody help me in resolving this problem?
Thanks and Regards,
Ranajit
If you have admin rights, it will show up in a Windchill search.
If you don't have admin rights, it may be in a workspace that you don't have visibilty rights to.
Find out who has already used that number and ask them to rename it or rename yours and check-in.
Search "1901065.asm" in windchill if existed, rename or delete the file and upload/checkin the new one.
Thanks for your inputs. I had to rename the assembly and check in the same.
-Ranajit-
