I'm just curious who has started using the new native task form templates in either their Production system, or their Test/Dev system. Who has plans to start using them?
I just released them into our Production system last night. I learned quite a few unexpected things along the way. And in this discussion, I'd like to collaborate on best practices with both my implementation and your implementation (or any questions you might have if you're investigating these native task form templates).
Hi Ben
I've tested the forms and I also have implemented it on different test servers. But not yet in production.
I do like the forms. Just if you have one not defined, an ugly old JSP page is being shown (That's something I really don't understand). So if you switch, you have to define for each Workflow Task a general or specific form template.
There are also some bugs e.g. for the CAPAPlanAction Type no template can be created.
What are your experiences?
Björn
Is Bjorn the only one who has taken a hard look at native task form templates? I figured there would be more people interested in this topic? Maybe this bump will get some different visibility today.
Sorry for leaving you hanging for a few days. Priorities.
To All,
I wanted to share my experiencing implementing the new Native Task Form Templates (Native TFT) that were introduced in 10.2 M030. The reason I would like to share my experience is because it didn't go as smoothly as I hoped. But there was nothing show-stopping. I hope this is a good resource for others looking to implement them.
Please be aware that this example focuses on the Change Notice as the PBO. But you can create native TFT for any PBO. For example, if you route WTDocuments, you can create different native TFT for them, and show different PBO tables.
Benefits
PBO information is visible on the same page as the workflow task.
User's don't need to navigate away to other pages to find the most commonly requested information when performing a task.
Users can do things such as view attachments, view CAD in Creo View, add objects to the workspace, etc ... all from the workflow task page.
Keys
Surprises
Summary
I hope you find this posting helpful. I am excited about native TFT. It is a great UI & user experience enhancement. PBO information used to be below the workflow task in Windchill 9.1. I'm glad to see it return in the form of these native TFT. Please find the screenshot below of the finished product, with an overlay of the configurable options for the native TFT.
Ben - Thanks for pioneering on this.
The revert to Default is one issue that will impact timing for sure! I'm also curious if you have any process variables in your TFT's and how you may have handled that.
Definitely interested and it's on the radar to explore/implement - when, not if.
I am very glad you asked that question. In fact, it reminded me of something I missed in my posting - the layout.
In M030, a new layout was added for the Work Item in Type and Attribute Management. When you are modifying the workflow activity in the Workflow Template Administration, you need to change the activity to use Native template instead if JSP template. When the activity's template is set to JSP, then "Task Info Page Layout" will be used. When the activity's template is set to Native, then the "Workflow Task Layout" will be used.
The above clarification should have been added to my "Keys" section. But it appears I'm unable to edit my reply.
Now, to answer your question... Yes, we use a lot of process variables. The Attributes section of the native TFT. That section looks at the Workflow Task Layout layout in Type/Attribute Manager. I've pasted a sample of that below. I created a separate section just for the process variables.
Ben - Tasks for Change Process is indeed available in Windchill 11.0
We have started to explore into the Native Task Form Template feature,
We are just in Test System right now with this and have realized that, If we add Subject Attributes and Workflow Attributes in the same tab, We dont see the Subject attributes.
Example we have added Subject information on the CA Task page thinking that Subject Attributes will give the users the CN information as well, However without any luck.
What we have seen is, If you create two tabs, first has Workflow attributes and second has Subject Attributes, It works as intended.
Anyone has same experience?
