Windchill 10.2 Keyword search doesn't find Change Request
  • August 19, 2016
  • 1417 views
When searching for a single piece of text in the "Description" section of a Change Request via the Keyword search in Windchill 10.2, the Change Request is not found. Is that expected behavior?
If I search for a single piece of text in the "Name" of a Change Request via the Keyword search in Windchill 10.2, the Change Request IS found.
Best answer by TomU
The keyword search is only looking at "Name" and "Number".  You will need to perform an advanced search and add "Description" to your criteria.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS80334
TomU23-Emerald IVAnswer
Thank you for that insight Tom. Adding the field "Description" to a Saved Search did the trick!
