Windchill 10.2 Keyword search doesn't find Change Request
KeithVieira
When searching for a single piece of text in the "Description" section of a Change Request via the Keyword search in Windchill 10.2, the Change Request is not found. Is that expected behavior?
If I search for a single piece of text in the "Name" of a Change Request via the Keyword search in Windchill 10.2, the Change Request IS found.
TomU
(To:KeithVieira)
The keyword search is only looking at "Name" and "Number".  You will need to perform an advanced search and add "Description" to your criteria.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS80334
TomU
(To:KeithVieira)
KeithVieira
(To:TomU)
Thank you for that insight Tom. Adding the field "Description" to a Saved Search did the trick!
