Windchill 10 integrate with Microsoft Active Directory is working?
ptc-3516347
Windchill 10 integrate with Microsoft Active Directory is working???
Someone has already done Windchill10 integration with Microsoft Active Directory, I did the same procedures used in version Windchill 9.1 and not work. I open case in PTC and has 4 months and nobody has solved the issue.
This issue is not integrate with Microsoft AD.
The build is F000 today I will update for M010 for check is I have a luck thai this working.
I can not imagine that around the world do not have any deployer that has made such integration.
6 REPLIES 6
Can't you treat the AD like any other ldap?
Create the ldap adapter. Create the repository for the adapter.
provider url: ldap://xxxxxx:port
user to connect with: cn=xyz,ou=abc
credentials: xyz
search base (where users are located): ou=users,dc=com,dc=xyz
search scope: subtree?
additional properties
com.adldap.windchill.mapping.user.objectClass: user
com.adldap.windchill.mapping.user.uid: sAMAccountName
com.adldap.windchill.mapping.user.uniqueIdAttribute: sAMAccountName
com.adldap.windchill.mapping.usersOrganizationNamexyz
I do this. This is part of the procedure. Thanks!
Please try using attached approach. Very simple, robust.
Oops - It appears that you can't attach a file (am I missing how to do so??) - write to me directly if you like and I'll supply a PowerPointon how to do this.
mike.lockwood@alconlabs.com
Oops - It appears that you can't attach a file (am I missing how to do so??) - write to me directly if you like and I'll supply a PowerPointon how to do this. mike.lockwood@alconlabs.com
We have actually abandoned the approach posted previously - now working on a much more standard integration with our new corporate parent. Only complexity (which has been a major problem) is that some users were created long ago in EnterpriseLDAP branch of Aphelion.
So - My current advice is to ignore my previous postings and rely on PTC's approach to A/D integration..
