Hi Guru's
I have a workflow with a set up participant activity. The roles are resolved correctly.
I want to make sure that the user selects at least one participant before completing the activity. How to achieve this?
Is there a customization to make the participants required?
Pradeep Shinde
Add an expression to the Complete transition of the activity. Throw a WTException if the requirements are not met. You can find most, if not all, of what you need in wt.team.TeamHelper.
Is there any way that I can mandate the user to select atleast one participant from each rolse displayed? Can I display an alert message to select atleast on participant from each role.
Hi Pradeep,
I have similar requirement, Did you get the code to check the participant user ?
If so kinly share, I need it badly...
Birendrasingh Rawat
