just wanted to double check w/ Community if there is any Windchill API that can be used to read information from OL file. I need to get mass properties out from there (I am assuming the adapter outputs them in the OL, not the PVS, file).
Thanks.
I am sure there is. I would start here:
There might be a class in com.ptc.wvs.common.util but I doubt any of this is supported.
Maybe it’s possible with the Creo Toolkit.
https://www.ptc.com/en/support/article/cs245285
