Version: Windchill 12.1
Use Case: How to obtain/create Windchill Virtual Desktop Image for ease of development on developers local machine.
Description:
Hi @PG_11148141
So install the Windchill in local virtual machine. I use HyperV.
I also used a VMware in the past without any problem.
PetrH
Hi @PG_11148141
PetrH
Hello @PG_11148141,
It looks like you have a response from a community member. If it helped answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
