Windchill Method Server StackOverflow error
ZahyMatar
6-Contributor
We have been having the following error after a rehost:
2024-04-18 12:05:08,566 FATAL [main] wt.method.server  - MethodServerMain abort java.lang.StackOverflowError
  at wt.util.WTProperties.getProperty(WTProperties.java:1421)
  at wt.util.WTSystemProperties.getProperty(WTSystemProperties.java:100)
  at java.base/java.lang.System.getProperty(System.java:854)
  at java.base/sun.net.NetProperties.get(NetProperties.java:94)
It does not happen initially and the new instance will run fine but if we restart the instance of Windchill or refresh the database, we are presented with that error. I have tried to resolve this with CS370256 but we are stuck at this point.
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
Which version of Windchill? Did you use the rehost script, or manually rehost?
ZahyMatar
6-Contributor
(To:jbailey)
We are using Windchill 12.0.2.4.
We ran the rehost script.
