Is there a way to add attributes without having a default value? I tried using the AllClients.xml file to not display the default value, but it didn't appear to work for classification attributes.
I may be missing something, but it seems like it should require a default value.
TIA
Steve D.
We are in the process of upgrading to 10.1 and the AllClients.xml file is no longer supported. I have not found a way to remove the need for default values on Classification attributes or the display of default values on Classification attributes.
