Version: Windchill 12.1
Use Case: I had to add/update the data formats .mp4 .avi .. to the existing formats "MPEG Movie Clip"
Description:
When i follow the guide "Updating Data Formats" in the Help:
Without SSO here is the request
Is there another workaround except turn off SSO ?
It depends on how you have SSO configured. The Windchill command is just Java with a wrapper. Generally, we can substitute 'windchill' for 'java' anywhere PTC a Windchill shell. Then follow this article for passing the SSO username.
https://www.ptc.com/en/support/article/CS63015
Use windchill --javaargs="-Dwt.auth.trustedAuth.username=username" wt.content.DataFormatUtil -update
There are a few other tricks if that doesn't work.
Thank you,
same way solved in this article CS353022
Article - CS353022 - How to execute java program / utilities in Windchill Shell when SSO (Single Sign On) and SSL (HTTPS) are enabled in Windchill PDMLink
