Windchill WGM with NX Viewer
Dobi
For the multi-CAD users here that use NX, has anyone tried connecting NX Viewer to WGM?
Dobi
(To:VladimirN)
This is a little different. We use NX with Windchill and that works fine.
The NX Viewer is a lower-tier option (kind of like CreoView) that uses a much less expensive license. I reached out to tech support and it turns out NX Viewer connection to Windchill is not supported... much the same as CreoView wouldn't work with data in TeamCenter.
VladimirN
(To:Dobi)
Take a look here - "Starting Siemens NX registered to Windchill Workgroup Manager , shows the WGM Authentification Window instead of starting the WGM": https://www.ptc.com/en/support/article/CS104974
Dobi
(To:VladimirN)
