How can I add data to our custom attributes via the WRS API? We have an attribute for WTParts called "CAT_CODE" and I want to add data to it via the CreatePart command (http://##.###.#.##:##/Windchill/servlet/odata/v5/ProdMgmt/Parts). My data is:
"DefaultUnit":{},
"EndItem":False,
"GatheringPart":False,
"DefaultTraceCode":{},
"PhantomManufacturingPart":False,
"ConfigurableModule":{},
"Name":"pyapitest",
"Source":{},
"AssemblyMode":{},
"Uses@odata.bind":[],
"DescribedBy@odata.bind":[],
"References@odata.bind":[],
"PartDocAssociations@odata.bind":[],
"Context@odata.bind":"Containers('OR:wt.pdmlink.PDMLinkProduct:109352')",
"Folder@odata.bind":"Containers('OR:wt.folder.SubFolder:155247')",
"CAT_CODE": "52",
}The error code I get when running the POST command is
{"error":{"code":null,"message":"'CAT_CODE' can not be mapped as a property or an annotation."}}
Ok, I had a couple issues with the data. The corrected data is:
"DefaultUnit":{},
"EndItem":False,
"Name":partname + "_pyapitest",
"Source":{},
"AssemblyMode":{},
"CATCODE":"520000",
"Context@odata.bind":"Containers('OR:wt.inf.library.WTLibrary:110138')",
"Folder@odata.bind":"Folders('OR:wt.folder.SubFolder:155247')",
The weird thing is that our IBA "CAT_CODE" can only be mapped when we remove the underscore and make it "CATCODE"...
"DefaultUnit":{},
"EndItem":False,
"Source":{},
"AssemblyMode":{},
"CATCODE":"520000",
