I want to make a workflow that has multiple approvers in the same role. If all of the approvers have a vote of approved, the primary business object will be approved. If there is 1 vote to reject, the primary business object is rejected without allowing the remaining voters a chance to vote. The problem is, when a reject vote is counted, the workflow waits until it has the rest of the votes in. This is not a good use of time since it will ultimately be rejected regardless of the rest of the votes. Is there any workflow logic that I am missing that would allow me to do this?
All votes approved -> Approved after all votes
1 or move vote rejected -> Rejected on the first Rejected vote
Thanks!
Melissa
Here is an example using a Synch robot to reject on the first vote -
Reject on 1st Reject Vote.pptx
Hope this helps
Hi Melissa,
having same requirement, 1 month ago I'd open a call to PTC Support to have a hint: actually they're still working on it! As far as I got answer, I'll leto you know about.
Kind regards
Melissa
Hope this helps
I tried this out and it worked. Thank you so much!
