Windchill+ and CATIAV5
simo893
7-Bedrock
Version: Windchill 13.0
Use Case: In order to connect CatiaV5 to Windchill+, 3° party Libraries are required to use Workgroup Manager ? In addition, also Theorem libraries have to be installed in order to publish with worker ?
Description:
i
Hi @simo893
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Best Regards,
Community Moderation Team.
I'll try to explain in more detail.
In order to connect CatiaV5 to Windchill, 3° party Libraries must be installed on clients otherwise the Workgroup manager will not work.
My question is, if i have Windchill+ instead WIndchill, these libraries are still necessary ?
