Hello
In 10, Windchill allow you to link different CADpart (different representation)to a single WTpart number. One by owner link , and the others by image links.
But it assumes it is the same part (for an electrical harness = the same length, but with a different form, due to his path in the product)
So the quantity will be for example2, unit each ... It will not solve your use case.
You can as said Brian, put your parts in the CAD assy, and marked it "not for build" . So let you update the WTpart BOM manually ...
You can also let ProE build the eBOM with a "each" quantity (and may be designate the Length parameter of you CAD part), and use MPMLink to "transform" this in mBOM with the correct UOM.
Anyway. You should create an idea for this case. Beeing able todefine a unit and the"driving quantity parameter" in some CAD Part, to build corretly this case in the WTpart BOM. I will vote for it !
regards
Gregory
