Windchill: removal of product.
bbusschers
In the past we have created some products in our Windchill database, which have some problems.
e.g. they are not "extended" and because of that hard to extend with local users.
I want to "clean" the database and delete these not used products.
Can anyone explain to me how to do that?
Thanks.
With kind regards,,
Bert Busschers
Sr. Mechanical Designer/CAD Administrator
ME/ID Department
[cid:image001.jpg@01CED61C.36F02820]
Lelyweg 10 - 7602 EA Almelo - The Netherlands
+31 546 535209 (tel)
+31 546 535299 (fax)
Bert.Busschers@bench.com<">mailto:Bert.Busschers@bench.com>
www.bench.com<">http://www.bench.com>
MCAD Mananger Benchmark
BenLoosli
(To:bbusschers)
Windchill 9 and prior you cannot delete a product once created, only rename them. Not sure if 10 has changed this restriction.
Still the same in 10. You cannot delete a product or library through GUI.
Thanks!
Rajesh Balasundaram | Corning Cable Systems | o 817.431.7337 | c 817.676.2868 | IT Site Leader - Keller | Windchill System Admin
