Windchill takes long time to startup
YZ_10818805
30 mins
how to fix
Ensure there are indexes on table wtgroup
6 REPLIES 6
Ensure sufficient memory
Ensure proper communication between Windchill and database server
Ensure LDAP is functioning properly
The information you mentioned is all normal
We have rebuilt the wtgroup table before, is it related to this?
Moreover, there is this information in the log
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3867)
 - locked <0x00000003c74090c8> (a oracle.jdbc.driver.T4CConnection)
 at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1502)
 at wt.pds.AbstractResultCursor.executeQuery(AbstractResultCursor.java:575)
 at wt.pds.AbstractResultCursor.executeQuery(AbstractResultCursor.java:539)
 at wt.pds.BasicResultCursor.getNextResultSet(BasicResultCursor.java:282)
 at wt.pds.BasicResultCursor.advance(BasicResultCursor.java:234)
 at wt.pds.BasicResultCursor.next(BasicResultCursor.java:82)
Yes, we miss index
Thank you
Those are just a few possible causes.  Search PTC's knowledge base for "windchill slow startup" to get many more possible solutions.
thanks, I will check that.
