I'm able to exeucte Windu now and the tasks started or completed now.
https://www.ptc.com/en/support/article/CS151715
Article - "How to run WinDU tasks for upgrade preparation in Windchill": https://www.ptc.com/en/support/article/CS71519
Hi @BP_11893543
You should use correct user that is the administrator in Windchill.
the error mention it
The user you attempted to login is not an administrator
PetrH
Hi @BP_11893543
This is just a bypass the user login . U would recommend to set this property back after the WinDu will finish
PetrH
