Creating a report based on information from the "Promotion Request"
VladiSlav
Hello, please tell me how to use Query Builder to get a report that will display the contents of the "Process Status" table from the "Promotion Request"?
I want to output all the queries for a certain period, but I failed in solving the issue.
I have a report that returns information close to what you're looking for. Try joining these:
Context is optional, if you don't need it for your reporting, you can leave it out. (I like having that info).
WF Voting Event Audit contains the user's vote and user comment. It is only filled in if the task is completed. If you want to have this info, but also want to return open tasks that aren't completed yet, you'll need to use the "Outer Join Against " option on the join, set to WF Voting Event Audit.
WF Assigned Activity is where you can get Task actual start and actual finish
Workflow Process is where you can get info on the overall process, like start time and finish time as not all tasks may be assigned when the workflow is initiated.
9 REPLIES 9
Below a list taken from PTC TS article about query builder report for Promotion e Workflow.
A more comprehensive list in this document
Take a look also to this article
How to generate a report with events from workflow tasks
https://www.ptc.com/en/support/article/CS32218
How to retrieve records for delegation/reassignment
https://www.ptc.com/it/support/article/CS39534
Report listing all open Work Items assigned to a user within a specific context
https://www.ptc.com/en/support/article/CS42158
How to add Promoted By and Promoted On in advanced search criteria
https://www.ptc.com/it/support/article/CS55947
Report to fetch Promotion Request records
https://www.ptc.com/en/support/article/CS112325
How to generate report to display "Promoted on" attribute from the Maturity History table of an object
https://www.ptc.com/en/support/article/CS115668
How to get Primary Business Object name from WfVotingEventAudit table using Report Manager
https://www.ptc.com/en/support/article/CS130932
Report to fetch completed task with approvers
https://www.ptc.com/en/support/article/CS137008
How to generate a report that will show the documents, their Promotion requests and the name of the context
https://www.ptc.com/it/support/article/CS141905
Windchill Data Model for Workflow related objects
https://www.ptc.com/en/support/article/CS153902
Report to fetch reassign information of a promotion request
https://www.ptc.com/en/support/article/CS162802
Query all workflows to determine for class/method used in them
https://www.ptc.com/it/support/article/CS168660
Report to list workflow tasks assigned to disconnected users
https://www.ptc.com/it/support/article/CS178728
How to generate QML report for the Tasks past deadline
https://www.ptc.com/en/support/article/CS180709
Report returning runtime routing list for Setup Participants from a workflow
https://www.ptc.com/it/support/article/CS210243
In which database tables are stored the workflow execution objects?
https://www.ptc.com/it/support/article/CS214035
Report to find out values of Promotion Preferences
https://www.ptc.com/it/support/article/CS215586
Report to fetch the Open Task assigned to User in a Product
https://www.ptc.com/it/support/article/CS246581
How to link SignatureLink and Workflow Process table and fetch data from them
https://www.ptc.com/it/support/article/CS258046
Report to get the Actual Start and Actual Finish of Assigned and Completed Workflows
https://www.ptc.com/it/support/article/CS284873
Is it possible to display in Query builder (tasks from the WFBlock) and (tasks from the WF)
https://www.ptc.com/en/support/article/CS306945
How to query or get report for activities that are of type "Set Up Participants"
https://www.ptc.com/en/support/article/CS310537
How to display all open tasks for all users on my homepage
https://www.ptc.com/en/support/article/CS321622
Report to list processes which may have tasks existing under them but are not open
https://www.ptc.com/en/support/article/CS341897
How to get an assigne name (in a role) from a workflow (Community)
https://community.ptc.com/t5/Windchill/In-the-query-builder-report-how-to-get-an-assigne-name-in-a-role/m-p/263254
How to generate a report of all completed Promotion Requests?
https://community.ptc.com/t5/forums/replypage/board-id/Windchill/message-id/63198
Query Builder Lifecycle History Example
https://community.ptc.com/t5/Windchill/Query-Builder-Lifecycle-History-Example/td-p/444736
Report on Workflow Processes
https://community.ptc.com/t5/Windchill/WindChill-Reports-Query-Builder-Locating-Fields/m-p/737015#M64301
Report showing date of last promotion
https://community.ptc.com/t5/Windchill/Report-showing-date-of-last-promotion/td-p/223769
Marco
thank you for the links, I've seen your message before.
https://community.ptc.com/t5/Windchill/Query-to-get-history-of-Change-Notice-like-Created-by-Number/td-p/185313
But not one solution did not give the desired result
Most of the support articles were written in response to a user request (some I did myself).
If you have active maintenance support, you could open a call and ask if they can give you a suggestion from which to build your report.
That way, if there is a positive response, I could add this to my list as well.
Marco
There isn't a "Process Status" table on Promotion Request - likely you are interested in something similar.
Regardless, I can help if you  are more specific.  Maybe screen capture from a Prom Req what you'd like to see in a report.
TomU
(To:MikeLockwood)
@MikeLockwood wrote:
There isn't a "Process Status" table on Promotion Request...
Yes there is:
thank you very much for your answer. You helped me, this is what I need.
Please tell me how I can add a list of options to choose from for the Context?
Glad I could help!
I think the query reports will only give  you a drop down list if the parameter is constrained by an enumerated list. I'm not really sure how to get a drop down list otherwise.
thank you! very helpful.
