Since the PTC Community hasn’t answered these questions, I’ll ask the exploder.
I am on Windchill/PDMLink 10.0 m040 with Creo 2.0 m100.
1)Under Organization preferences for Windchill, in the Promotion Process tab, there is a value for Default Promotion Processes. This is set to the custom promotion process that we use. Under the Change Management tab, there is no setting for Default Change Request Process, only Default Change Task Name. How do you specify a custom Change Request Process, Change Activity or Change Notice process? Does this mean that the only change management workflows that can be utilized are the default OOTB named ones?
2)I have added some Roles at the Organization Level. I have placed people in these roles at the Product and Library levels. Is there a way to place names to a role at the Organization level?
3)I now need to assign these roles to be participants in an Assigned Activity in a workflow. The added roles are not showing up in the list of Roles for selection. What do I need to do to make the roles available to a workflow?
