Hello Antonio,
I know this is a very old thread but was the only one in this entire forum talking aboutDefaultDataUtility class, I am trying to use it to remove the iteration number from the UI, a customer does not use it at all, he is all about versions in his process, so I tried it using the attached class, which is being applied but the iteration number is still there, do you know if that is possible?
Guilherme Rocha
