change revision label maximum value
I use Windchill 10.2. I'm an untrained Windchill admin for my company. For the first time we have a .prt and .drw that need to be revised to 21, our system seems to have the maximum numerical value set to 20. See the message from Event Manager below.
Either new revision value "21" is not valid, or it is not greater than the existing revision value "20". Specify an appropriate value for the new revision.
Where in the Windchill Utilities do I find the place to change the max value?
