compiling windchill .java files using ant
SimonLucas
trying to compile a windchill .java file using ant and having no success. The command on its own in a windchill shell works fine ie "javac -d %WT_HOME%\codebase %WT_HOME%\codebase\com\ptc\windchill\uwgm\proesrv\c11n\DefaultModeledAttributesDelegate.java".
I have tried both :
srcdir="${wchome}/codebase/com/ptc/windchill/uwgm/proesrv/c11n"
destdir="${wchome}/codebase/com/ptc/windchill/uwgm/proesrv/c11n"
includes="DefaultModeledAttributesDelegate.java"
fork="true"
memoryMaximumSize="512M"
nowarn="true"
debug="true" >
<classpath>
<pathelement path="class.path"/>
</classpath>
</javac>
and
<exec executable="${wchome}/bin/windchill.exe">
<arg line="javac" -d=" %wt_home%=" codebase=" %wt_home%=" codebase=" com=" ptc=" windchill=" uwgm=" proesrv=" c11n=" defaultmodeledattributesdelegate.java&quot;="/>
</exec>
but neither seem to work. IN both cases I get java errors.
Any ideas?
Cheers
Simon Lucas
Hi Simon -
Try declaring the properties you are using in the ANT file, and explicity add the PTC resources needed for compilation to the classpath:
<property name="windchill.home" location="C:/ptc/Windchill_9.1/Windchill"/>
<javac<br/>srcdir="${windchill.home}/codebase/com/ptc/windchill/uwgm/proesrv/c11n"
destdir="${windchill.home}/codebase/com/ptc/windchill/uwgm/proesrv/c11n"
includes="DefaultModeledAttributesDelegate.java" fork="true"
nowarn="true"
debug="true" >
<classpath id="classpath">
<pathelement location="${windchill.home}/codebase"/>
<pathelement location="${windchill.home}/codebase/WEB-INF/lib/ie.jar"/>
<pathelement location="${windchill.home}/lib/wnc.jar"/>
<pathelement location="${windchill.home}/codebase/WEB-INF/lib/wncWeb.jar"/>
<pathelement location="${windchill.home}/codebase/lib/log4j.jar"/>
<pathelement location="${windchill.home}/lib/servlet.jar"/>
</classpath>
</javac>
Let me know if you are still having problems.
Thanks -
Todd
Todd,
many thanks -including the individual pathssolved the issue. Obvious thing to do really I guess - when your brain is swithed on 🙂
Simon Lucas
