contradictory conditions in publish rules
Hans_TS
3-Newcomer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.8
Is it possible to have contradictory conditions in publish rules.
We want to have a condtion in the publish where content (STEP/PDF) only is published when attribute MODEL_TYPE is empty. If this value is not empy it should not publish any content only the pvz.
HelesicPetr
(To:Hans_TS)
Hi @Hans_TS
But you use regex definition in the value definition.
Iam sure that it can not work.
use <or> definition for each value or use regex= parameter instead of value=
PetrH
9 REPLIES 9
Hans_TS
3-Newcomer
(To:Hans_TS)
We already tried the following:
<condition name="3DPRT_released">
<and>
<attribute name="epmdoc_docType" value="CAD Part" />
<attribute name="epmdoc_MODEL_TYPE" regex=")$" />
<or>
<attribute name="epmdoc_lifeCycleState" value="Design Review" />
<attribute name="epmdoc_lifeCycleState" value="Design Approved" />
<attribute name="epmdoc_lifeCycleState" value="Design Manual Approved" />
<attribute name="epmdoc_lifeCycleState" value="Prototype" />
<attribute name="epmdoc_lifeCycleState" value="Production" />
<attribute name="epmdoc_lifeCycleState" value="Obsolete" />
</or>
</and>
</condition>
Publish rule has no error but when attribute MODEL_TYPE is empty is not publishing any content
HelesicPetr
(To:Hans_TS)
Hi @Hans_TS
Empty? so try value=""
PetrH
Thank you for your response.
We already tried that but this is not working.
This is resulting in an error during replacing the publish_rules.xml.
H.smits
HelesicPetr
(To:Hans_TS)
So if it does not work you need to find better way.
For example why the parameter should be empty? use some default or not empty value that you can use in the condition.
PetrH
It could be configured in two ways.
1. attribute value is empy
2. Attribute is not .....|...|
Do you know how to set up the rule that the value must not have some value?
As example
<and>
<attribute name="epmdoc_MODEL_TYPE" value=not "SOLIDPART|SHEETMETALPART" />
<or>
HelesicPetr
(To:Hans_TS)
Hi @Hans_TS
Check the help
Using Conditions in Publish Rules
Examples of Publish Rules XML Files
Supported element NOT
<not>
    <attribute name="epmdoc_lifeCycleState" value="Released" />
</not>
PetrH
I tried the following:
      <and>
        <not>
<attribute name="epmdoc_MODEL_TYPE" value="(SOLIDPART|SOLIDPART).*$" />
      </not>
        <or>
        </or>
      </and>
Now the additional output is created as a step file when attribute MODEL_TYPE is empty but when it is set to example SOLIDPART it will also create a stepfile so it is not working as we want.
HelesicPetr
(To:Hans_TS)
Hi @Hans_TS
PetrH
Thank you I think this is the solution.
