I changed the config.pro option
save_instance_accelerator saved_objects
to
save_instance_accelerator none
Then I was able to save the assembly. I achieved the desired outcome -in my workspace, the part that I modified and the assembly I saved both show up as "modified locally".
So what's up with the instance accelerator files issue? Does anyone have any more experience working this way?
Even if it is an old topic, here what we do when it happens.
Basically it can happen trying to save an assembly even if it is checked out.
Creo seems not to be able to properly save the accelerator file of components of the assembly.
My workaround is to open the generic file of the mentioned components and trigger a verification of the family table via a change, usually by adding a datum plane.
Afterwards the a component can be saved and also the upper assembly
greets
Walter
