Good day PTC Users!
We have created a wtpart subtype with a number of custom attributes. Now, certain attributes have become out dated and need to be removed.
If one goes to the type definition utility and remove it from the subtype then it removes OK but when one views the attributes of an existing part then the attribute is still there.
Also I have tried removing the definition for the attribute via the manager but it says that it cant be deleted since it is current in use (which makes sense).
Is there any way that one can remove values/instances of this attribute from existing parts.
Looking forward to hearing from you
Hello
what about a work around where you hide the attributes to the end users.
