Hi All,
I've set up the office worker on a separate server using the Adobe Experience Manager. The Worker Daemon is started from a CMD Window and not set as a service.
While publishing the doc2pv.exe application crashes.
Details: Windchill 10.2
Creo View Adapters 3.0
Adobe Experience Manager 6
The application crashes while publishing an Excel Doc (see attachment) . For Word the job fails directly with the following error:
17.08.2016 09:55:39:Failed to publish document file "D:/FTP/worker/w1i1j6/test.docx" to "D:/FTP/worker/w1i1j6/test_docx.pdf"
17.08.2016 09:55:39:Document Processing Returned: $ERROR$ Failed to publish document file "D:/FTP/worker/w1i1j6/test.docx" to "D:/FTP/worker/w1i1j6/test_docx.pdf"
17.08.2016 09:55:39:CadAgent Returned: $ERROR$ Failed to publish document file "D:/FTP/worker/w1i1j6/test.docx" to "D:/FTP/worker/w1i1j6/test_docx.pdf"
file=doc2pv-rcp
ver=5
lastp=conv
adapter/mergeProperties=0
adapter/serverVersion=1000
adapter/useAdobeLiveCycle=1
adapter/LCserver=localhost
adapter/LCport=8080
adapter/LClogInId=administrator
adapter/LCpasswd=password
adapter/enableCommenting=1
adapter/LCreaderExtnAlias=PTS
You must set the adapter/LCreaderExtnAlias property.
Copy the folders "i486_nt" and "recipe" to "doc_setup" folder.
Copy the file bin\doc2pv.exe to "doc_setup" folder.
Change paths in the files docworker.bat and docbatch.bat.
Hi Sergey,
This solved the crash of doc2pv but the publishing job still fails with the following message:
:Failed to publish document file "D:/FTP/worker/w1i1j2/test.doc" to "D:/FTP/worker/w1i1j2/test_doc.pdf"
25.08.2016 11:46:50:Document Processing Returned: $ERROR$ Failed to publish document file "D:/FTP/worker/w1i1j2/test.doc" to "D:/FTP/worker/w1i1j2/test_doc.pdf"
25.08.2016 11:46:50:CadAgent Returned: $ERROR$ Failed to publish document file "D:/FTP/worker/w1i1j2/test.doc" to "D:/FTP/worker/w1i1j2/test_doc.pdf"
25.08.2016 11:46:50:End (with Error): Document - 0000000024, test, A.1
25.08.2016 11:46:50:End job (with error): Document - 0000000024, test, A.1
Alex
You need to check the local publishing with docbatch.bat
if I try that I get this error:
D:\ptc\creo_view_adapters\doc_setup>docbatch.bat D:\FTP\worker\w1i1j2\test.doc
Recipe file: D:/ptc/creo_view_adapters/doc_setup/doc2pv.rcp
Source file: D:/FTP/worker/w1i1j2/test.doc
Output file: D:/ptc/creo_view_adapters/doc_setup/test_doc.pvs
Publishing document : COMPLETE
doc2pv Error:63002: Failed to publish document file "D:/FTP/worker/w1i1j2/test.d
oc" to "D:/ptc/creo_view_adapters/doc_setup/test_doc.pdf"
I tried the solutions from found on the support page for the Error:63002: Failed to publish document file but the situation is the same.
Can I see your doc2pv.rcp file?
Turn Off option "Rely on system fonts only; do not use document fonts" in the Adobe PDF printer.
file=doc2pv-rcp
ver=5
lastp=conv
adapter/LCport=8080
Publishing document : doc2pv Error:63012: Failed to enable pdf commenting
COMPLETE
Now its a different error
Thanks Sergey,
Seems to be working fine now.
Alex
Hi Alexandru,
ReaderExtension Credential alias in adapter configuration might be incorrect. Refer the below support article to correct it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS150853&source=articleshare&art_lang=en
