Version: Windchill 11.1
Use Case: LEOparts system
Description:
could you please provide me solution:
in fact i received error message during the complete task of "Standard Change Request" SCR00001822 in side LEoparts system :
Windchill error occurred completing work item!
Message: Resource bundle/Message key = wt.pom.pomResource/9 "
thanks for urgent support
There is not enough information to investigate the issue. What is LEOparts? Can you add a Windchill Method server log file?
