So, I have successfully coded an expression robot to move objects from one subfolder to another...within the same Product, but I have need to move them from one Product to another.
i.e.:
FROM current location...
site/myOrg/Product_WIP/SomeAreaFolder/CurrentFolder
TO location...
site/myOrg/Product_PROD/Somewhere/DestinationFolder (just need the java address of this?)
In java, the initial address is "/Default/AreaFolder/CurrentFolder". I can move object anywhere within Product_WIP or /Default no problem, such as "/Default/AreaFolder/NewFolder".
With "/Default" being the "top" folder (which is 1 Product_WIP)...how do I address for folders in Product_PROD? Normal java relative paths do not work like "../folder-up1level".
~PB
here is my code...
wt.maturity.PromotionNotice promotionNotice = (wt.maturity.PromotionNotice) primaryBusinessObject;
wt.fc.QueryResult queryResult = wt.maturity.MaturityHelper.service.getPromotionTargets(promotionNotice);
String objectTypeName = null;
while(queryResult.hasMoreElements()) {
wt.fc.WTObject object = (wt.fc.WTObject) queryResult.nextElement();
com.ptc.core.meta.common.TypeIdentifier objectType = wt.type.ClientTypedUtility.getTypeIdentifier(object);
//objectType = object.getClass().getName();
objectTypeName = String.valueOf(objectType);
if(objectTypeName.contains("wt.part.WTPart")){
try{
wt.folder.FolderEntry fentry = (wt.folder.FolderEntry) object;
wt.folder.Folder f = wt.folder.FolderHelper.service.getFolder(fentry);
//the following line works fine, as I am moving the object within Product_WIP ("/Default")
// wt.folder.Folder fldrloc = wt.folder.FolderHelper.service.getFolder("/Default/SomeAreaFolder/CurrentFolder/test-within-same-folder", ((wt.inf.container.WTContained)object).getContainerReference());
//the following line DO NOT work, as I am trying to use relative paths...which (in my thinking) would allow me to get to other Products
wt.folder.Folder fldrloc = wt.folder.FolderHelper.service.getFolder("../Test-up1level", ((wt.inf.container.WTContained)object).getContainerReference());
wt.folder.Folder fldrloc = wt.folder.FolderHelper.service.getFolder("../", ((wt.inf.container.WTContained)object).getContainerReference());
wt.folder.Folder fldrloc = wt.folder.FolderHelper.service.getFolder("../../", ((wt.inf.container.WTContained)object).getContainerReference());
wt.folder.Folder fldrloc = wt.folder.FolderHelper.service.getFolder("../.././", ((wt.inf.container.WTContained)object).getContainerReference());
wt.fc.collections.WTValuedHashMap map = new wt.fc.collections.WTValuedHashMap();
map.put(object,fldrloc);
wt.dataops.containermove.ContainerMoveHelper.service.moveAllVersions(map);
moved = true; //needed for release conditional robot
catch(wt.util.WTException wex){
errorMsg = errorMsg + "...Cannot move because " + wex.getLocalizedMessage();
moved = false;
}else{
errorMsg = errorMsg + "...*if* was FALSE...";
Try adding this bit of code before your folder line to get the host or target context info:
wt.inf.container.WTContainerRef cref = wt.inf.container.WTContainerHelper.service.getByPath("/wt.inf.container.OrgContainer=<org name>/wt.pdmlink.PDMLinkProduct=<product name>");
I've recently had to implement this same thing and asked for help from one of our support vendors. Seems to work (thanks Kevin!).
If you're moving to a Library context, the wt.pdmlink bit above becomes wt.inf.library.WTLibrary.
