Hi All,
How to create query to get vaultFileName of FT??
There are articles on PTC
https://www.ptc.com/en/support/article/cs39037
https://www.ptc.com/en/support/article/cs337082
but I'm not able to create such query.
Any idea??
regards,
Hi @Gucio
here is MSSQL example how to get vaultFileName with CAD Model file name
this works only for normal CAD Documents
select substring(convert(varchar(100),convert(varbinary(100), FVI.uniqueSequenceNumber, 256),2),3,14) vaultFileName,apData.idA3A5 as FvItem, apData.fileName ,MSTR.documentNumber, EPM.versionIdA2versionInfo,EPM.iterationIdA2iterationInfo, MSTR.CADName from wcuser.EPMDocument EPM
INNER JOIN wcuser.HolderToContent CONTENT
ON CONTENT.idA3A5 = EPM.idA2A2
inner join wcuser.ApplicationData apData
ON apData.idA2A2 = CONTENT.idA3B5
inner join wcuser.EPMDocumentMaster MSTR
on MSTR.idA2A2 = EPM.idA3masterReference
inner join wcuser.FvItem FVI
on apData.idA3A5 = FVI.idA2A2
where MSTR.CADName like 'plech.prt' and EPM.latestiterationInfo=1
Following example shows how to get vaultFileName for FamiliTable
inner join wcuser.EPMContainedIn CONTIN
on EPM.idA2A2 = CONTIN.idA3A5
inner join wcuser.EPMSepFamilyTable FT
on FT.idA2A2 = CONTIN.idA3B5
inner join wcuser.HolderToContent CONTENT
on CONTENT.idA3A5 = FT.idA2A2
where MSTR.CADName='plech.prt'
Hope this can help.
PS: the select function changes a RealNumber value stored in a database to the final FilaVaultName value that is used in a storage
PetrH
hi Petr,
unfortunatelly I receive "Error at Line: 1 Column: 26". But in the meantime I used bello query:
SELECT
epdm.name,
epd.versionIdA2versionInfo||'.'||epd.iterationIda2iterationInfo VERSION,
to_char(fvi.uniqueSequenceNumber,'FM0XXXXXXXXXXXXX') "VAULT FILE",
fvm.path
FROM
EPMDocumentMaster epdm,
EPMDocument epd,
HolderToContent htc,
ApplicationData ad,
FvItem fvi,
FvFolder fvf,
FvMount fvm,
EPMSepFamilyTable sft,
EPMContainedIn ci
WHERE
epdm.idA2A2=epd.idA3MasterReference
AND htc.idA3B5=ad.idA2A2
AND htc.idA3A5 = sft.idA2A2
AND epd.idA2A2 = ci.idA3A5
AND ci.idA3B5 = sft.idA2A2
AND ad.idA3A5=fvi.idA2A2
AND fvi.idA3A4=fvf.idA2A2
AND fvf.idA2A2=fvm.idA3A5
AND epdm.cadname='ahu03-3-81453.prt'
Hi @Gucio
It is normal if your database has different name in my case wcuser
So you need to change all wcuser. to your databse name.
the SQL is written for MS SQL so for Oracle you need to change it to correct form.
I run the SQL script under database admin user so I always use nameDatabase.TableName in my SQL examples.
PetrH
