Hello guys ,
I want to hide Description attibute if it is not end item .it need to display only for end items .please suggest some approaches to achive it .
Thanks !
Since an End Item is not a subtype you won't be able to remove the attribute without customization. I would recommend a data utility which gets the dropdown menu of the end item and dependent on that, it will show the text box or not.
Hi Rohit,
I have done something similar in the past. Do you need to hide attribute on Create Wizard?
WD
when you flip the end item flag the attribute panel is getting refreshed.so apply a validator to hide the attributes.
