how to remove recover failed installation
rtj
Currently windchill 10 pdmlink is running and i tried of adding projectlink using solution installer as optional installation. had some errors and now some of services and third party services got corrupted . now i need to repair it
ChrisSpartz
(To:rtj)
What sort of errors did you run into?
If you re-run the PSI, it should detect the failed installation and prompt you to recover it.
rtj
(To:ChrisSpartz)
This is the error i am getting. I think some problem with the Pjl file i downloaded.
ChrisSpartz
(To:rtj)
Did you try redownloading the project link install file? Did that allow the install to complete successfully?
If it's still failing, then the PJL_PtcInstall.log should give a better idea of what's causing the failure. The log is located in the install/logs/ directory inside your Windchill directory.
