info*engine implementation how to do , i am newbe in plm as well as windchill
Manish,
Can you give some further information of what you're trying to do with Info*Engine? Are you trying to install it? Create I*E tasks/webjects? Something else?
Info*Engine Editor
I created a simple sample of Info*Engine for you.
It creates a document through using Info*Engine. It makes a document named as Sonata Hybrid. Please look up the tags below.
Windchill
The document is created in Sonata Product container.
Manish,
There are also a lot of examples of sample Info*Engine tasks/webjects available in the PTC Knowledge Base, including the following examples:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS32191
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS144109
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS225756
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS223891
This article provides links to a lot of the Windchill customization guides as well:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS212271
