java plugins not working on 10.1
sdakkach
Hello, I am currently using windchill 10.1 and the java plugins don't work. version of java is 1.7 and browswer firefox. Thank you for your help
Serge,
you can do a search in the community, typing java in the right upper corner.
Then you can filter results page on the left, choosing discussions, documents, ecc...
There are a lots of article/discussion about problems with Java.
Marco
ChrisSpartz
(To:sdakkach)
What happens when you try to open a Windchill applet? Is there anything printed to the Java Console?
Hey, thank you for your reply and help, I fixed the problem. I was told windchill only supported up to versions 1.7 whereas the plugin for the applet worked when i used firefox browser with java version 1.8(most recent). and not the older versions.
