Intralink 3.4 M060 migration to PDMLink 9.1 M020.
I have created a lifecycle called "Tech Pub" with one of its states named "In Work". When attempting to map my Intralink "Tech Pub" release levels I get an error when mapping to "IN WORK". The relevant section from epm_folder_rsrl_map.properties is this:
RS.DEF.BEGIN.Tech Pub
Tech Pub=Tech Pub
Tech Pub.1.PRELIMINARY=IN WORK
Tech Pub.2.PRODUCTION=PRODUCTION
RS.DEF.END.Tech Pub
When I attempt to reconcile Folder and Scheme/Release Level data I am getting the following error:
Conflicting Data Root Folder/Tech Pub
As you can see the error is complaining about the "IN WORK" state. I have tried enclosing IN WORK with both " and ' however that doesn't resolve the error. Does anyone know how to map to a lifecycle name with a space? Or point me to somewhere in the ProIDateMigAdminGuide_9_1_M020.pdf that documents how to map to a lifecycle with a space in the name.
Thanks to all who replied with the "leave out the space" in "IN WORK" so the problem line in epm_folder_rsrl_map.properties went from this:
Tech Pub.1.PRELIMINARY=IN WORK (incorrect)
to this
Tech Pub.1.PRELIMINARY=INWORK (correct)
"ildataloader.sh Mapping" will now happily reconcile the FOLDER and RELEASE SCHEME/RELEASE LEVEL data.
I think what one actually needs to do is take a look at the <windchill_dir>/src/wt/lifecycle/StateRB.rbInfo file and take a look at text string associated with the key and NOT the text string associated with the value which is what displays in the LifeCycle administrator. For example the "In Work" state is like this from StateRB.rbInfo:
INWORK.value=In Work
INWORK.shortDescription=In Work state
and as Josh pointed out Canceled turns into CANCELLED:
CANCELLED.value=Canceled
CANCELLED.shortDescription=Canceled state
Spelling 101???
