new part from template copy associated drawing, common name mapping to PDMlink name ?
ptc-46674
Looking for help getting this all to work properly ? see screen grabs in attached PDF
Basic situation
I've moved all of our template files into common space Library/proe standards/templates
example PART_TEMPLATE.PRT & PART_TEMPLATE.DRW
the drawing contains nothing more than the model "no format no view's"
I've updated the config.pro file to point to the correct folder!
when I create a new part using the PART_TEMPLATE.PRT & select copy associated drawing, mostly everything works... I get the new part and drawing in my workspace... the one thing I can not get is the common name value entered when creating the new part to map to the name field in PDMLink ?
also one weird thing I've noticed is no matter what I name the new part, the 1st time I save the file I get a message that the file already exist, do I want to overwrite it ? yes I have no otther choice...
anyone been through this tangled web of confusion, any insight into what I might be overlooking or doing wrong will be greatly appreciated.
We are running ProE wildfire 5.0 m050
PDMLink 9.1 m050
thanks
Dave
Dave McClinton
Sr. Mechanical Designer / MCAD System Admin
"RCP"
Richardson Cooling Packages, LLC
731 Moravia Street
New Castle, PA 16101
Phone: 724-698-1015
Fax: 724-652-4142
Email:dmccl@coolingpackages.com
Web:
Dave,
I use a relation in Pro/E to copy the value of the common name parameter
to the name parameter:
NAME=PTC_COMMON_NAME
Best regards
Jan
On Wed, 12 Oct 2011 23:42:10 +0200, Dave McClinton <->
> attached PDF
> Basic situation
> standards/templates
> in PDMLink ?
> PDMLink 9.1 m050
> thanks
> Dave
> Dave McClinton
> "RCP"
> 731 Moravia Street
